Well, I was doing some parts switching due to a recent upgrade, and I decided to upgrade the cooling on the Radeon 9700NP that would be going into my living room A/V system. I really wanted to go passive if possible, and I didn't feel like spending the ~$30 for the Zalman heatpipe unit, so I did something a little different...
I had a couple of these 60mm Swifty MC370 clones laying around that I had used before in some passive NB cooling projects, so I wondered if they would fit. I really like these HS because they are big, cheap, and decently light. I prefer to stick to aluminum when doing passive cooling since copper is much heavier, and really should be actively cooled.
Well, on to the pics...
First, I took off the stock HSF unit, and cleaned up the 9700's core with some 91% isopropyl alcohol.
Sapphire 9700NP all ready to be modded
Hmmm....will it fit?
I prefit the HS, and it did indeed fit. The only problem was it did touch a couple of the surface mounted components of the card. Notably, it touched two capacitors in one corner, and touched another one in the other corner.
Tight fit...
Also a snug fit...
The HS only barely touched the components, and didn't push on them, so I figured I would just avoid any possible chance of something shorting to the HS with a little electrical tape.
Tape..
More tape...
And even a little more...
Once I had that all sorted out, I mixed up some Arctic Silver thermal epoxy, and got to work. I got everything all mounted, put some weight on it, and let it set.
After a few hours, the finished product looked good...
Finished project...
another...
and another...
one more for good measure...
All in all a nice mod, and cheap!
:beer:
**Update 1/10/04**
Well, tonight I thought I would do some playing around and see just how much o/c-ability the cooling mod gave me, if any. The memory on the NP tops out @ a measly ~290 or so (3.3ns Infineon), and the core used to only hit about 305mhz (from the 275mhz default).
Well, I kept cranking the speed, and running some loops of 3D Mark 2K1, and kept waiting for artifacts or crashes, but none came. I am using the Rage3D Tweak program to overclock, and this 9700 just kept going right up to the max the app would let me o/c...~374mhz!! :Q:Q:Q
O/C Results
I ran about 30 loops of the 3D Mark bench @ all speeds. Does anyone know of a way I can o/c the core any more that where it is? At this rate, I am thinking 400mhz might be attainable. :Q
:beer:
Tight fit...
Also a snug fit...
Tape..
More tape...
Finished project...
another...
and another...
:beer:
**Update 1/10/04**
O/C Results
:beer:
