- Jul 23, 2004
- 3,554
- 0
- 0
Originally posted by: Dorkenstein
Whoops again. I am just trying to get a really good signal in my house. Running a cable right now but I can't keep it there forever. Is 5 or 6 ghz only the A standard?
Hmm. I will need one more router for this then. Is tomato better than DD-WRT as far as wireless strength/capability goes? Thanks.
Yeah I've tried powerline before. I bought the Panasonic kind, which was pricey.
Originally posted by: Spicedaddy
Like others have mentioned, 2.4GHz has better range.
In my experience, the best reception is with routers set up in Client Mode. I'd get 2 WRT54GL routers, use one as a standard router, and the other in client mode using dd-wrt or tomato firmware.
What's the difference in "client" mode and "bridge mode" (ethernet bridge)?
Sorry for the OT question....
Client Mode
Bridge mode
Basically in client mode, DD-WRT connects to your WAP as any other client and gets an IP address. Of course, you'll have 4 wired ports you can use and this DD-WRT client will have a DHCP server creating another subnet; a different network from your first WAP.
In bridge mode, the DD-WRT unit acts more like a switch, allowing any units wired to it to be part of the same subnet as the primary WAP.
