5.1 Speaker setup help
stev0
5,132
is there some program out there that will send a signal through my speakers to see if i have the hooked up the right way? (like "right front".... "left front".... "center"..... ect..) i know they have cd's like that but i can't find mine... :( please help!
fatbaby
Banned
May 7, 2001
6,427
what brand is your soundcard?
if its creative, go to startbar>programs>creative>soundblaster XXX>surround mixer
Click on the little icon that says "2 speakers", change it to 5.1, and click test...if all goes well you'll hear "left channel, right channel, rear left, rear right, center channel"
5489
2,163
if you have a dvd rom drive, some dvd's have that feature. i think Toy Story 2 is one of them, im not sure tho.
yellowperil
4,598
The Disney DVDs (Toy Story, Monsters Inc., etc.) and some others with THX have the channel test. It also lets you check if your speakers are in phase.
d33pt
5,654
my receiver has a feature that does that too... or you can just double check your damn wires.. not too hard
stev0
5,132
comp, i just put on a dvd and started unplugging the speakers... got it under control, thanks guys.
ThisIsMatt
Banned
Aug 4, 2000
11,820
Ah, you took the highly technical method, good job :p
(actually, I think that can be harmful to the amp)
stev0
5,132
nah it's all good... i've got the best buy warrenty thing ;)
