Hi all! I have finally received a set of Creative T5900 5.1 Speakers. They seem very good but for some reason it refuses to drive the centre speaker. My setup is AMD 64 3000+, with a DFI LanParty UT Nforce 3 250Gb. On that is a nVidia Soundstorm audio chip, apparently with 8 channels. I?m using Nvmixer 1.0 that came with the mobo, Audio Driver V4.45 (Or 6.14 it says both) with a single AC97 8 channel audio codec.
The last speakers I had where nTech 2.1?s, and the sub appeared to have burnt its self out. Whenever I plug any speakers into the Centre/Sub-woofer port on the IO panel I get nothing at all. I?ve tested with the speakers in my monitor as well, same, no response.
Now the most confusing this is when I run the speaker setup wizard in nvmixer I get sound out of them all, including the centre channel, and however I do it I get sound from the sub.
I have checked that both the control panel and nvmixer are set to 5.1 systems, and I?ve even re-installed the driver. Do I need a new sound card or is there something real noobish I haven?t seen?
Please reply even if you only have an idea, I?m desperate now! I will give mo re details if they are needed.
Dan
Dan
