5 1/4" 4 - Pin power extension cable
ares32585
79
Does anyone know where I can buy LONG (meaning 10 to 25")
5 1/4" 4 - Pin power extension cables? I need to connect two fans on opposite sides of the case.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,686
Dunno where you can find a cable like that, but I have a suggestion, a possible alternative. run one cable from the psu to the rear fan, and get a Y-adapter to use on the front to replace the moved connector. Unless, of course, you want to run the fans in series, might as well break out the soldering iron in that case.
