I have an i7.
I think I should go on with the Rampage option. I am just a bit sceptical because I dont want to be again in that position where after plugging the 3rd card I realise that there isnt enough space for the 4th card
Thanks
It will stop being an issue soon, from what I have seen Nvidia is getting rid of support for three and four way GPUs. I suspect AMD will start moving that way too.
Gaming really sees very very minimal gains from using more GPUs, once you get past 2 GPUs there is very little actual performance gained. The preference is always to get the highest powered single GPU possible, and if NEEDED (1440p 144hz and 4k+ res) dual high end GPUs will work with some games.
But triple GPU and quad GPU really never get supported by more than a handful of games, and even then the difference between 2 GPUs and 4 GPUs is negligible except at super high resolution or similar situations.
For GPGPU functions however, multi-GPU setups still make sense.
