- Aug 25, 2001
- 56,570
- 10,203
- 126
https://www.newegg.com/Product/Product.aspx?Item=9SIA5AD8P22252&ignorebbr=1
Does anyone know what a "Terascale" HDD is for? Are these a re-branded "Seagate Archival" HDD? Or something mfg'ed cheaply, for cloud providers? Limited firmware features? Are these SATA? Or PCI-E? (Edit: Specs say right there, "SATA III 6Gb/s".)
I really don't know. But as far as internal SATA HDD prices go, it seems like a decent one, if it's compatible. I don't know how the warranty works for drives purchased from goHardDrive, I assume that whatever warranty is through them.
Here's the Amazon listing:
https://www.amazon.com/Seagate-Terascale-3-5-Inch-Internal-ST4000NC000/dp/B00E262A06
https://www.seagate.com/files/www-c.../terascale-hdd-data-sheet-ds1793-1-1306us.pdf
- 4TB Storage Capacity
- 5900 RPM
- SATA III 6 Gb/s
- 64MB Cache Memory
- Sustained Read Data Rate up to 170 MB/s
- Affordable storage for 24x7 multi-drive replicated environments
- High vibration tolerance for reliable enterprise-class performance
- Low power and cooling costs with the lowest 3.5-inch enterprise drive operating power
- Advanced format logical block management for industry-leading data integrity
- 4TB per drive enables scalable high-capacity storage in 24x7 environments Lower TCO with Seagate Instant Secure Erase for simple drive repurposing or disposal SATA 6Gb/s interface optimizes burst performance
