Question 4k HDR display suggestions
kallekill
134
Im trying to find a 32" 4k monitor that also supports HDR 1000 and G-Sync but I have a hard time founding one. Seems like most monitors have very bad HDR support. Any suggestions?
kallekill
134
just get a oled 55" LG :p
I already have a 65 " LG Oled as a TV, but I'm afraid of using it too much with the computer because of burn in.
I found this Acer Predator cg437k P :
It looks good, but 43" is a little big. Maybe they will make a 32" version too.
mnewsham
14,539
428
43" 4k allows you to use it without any GUI scaling at normal desktop distance.
It has a 103 PPI, which for comparison, is very similar to other normal desktop monitors, 27" 1440p is 109 PPI, 22" 1080p is 100 PPI, so 103 PPI is right in that sweet spot for "normal" viewing distance at a desktop without any GUI scale needed.
32" 4k usually needs to be GUI scaled in order for text to remain legible at normal desktop viewing distances.
