coolamasta
Hi people, am rather fed up now at getting my i7 920 stable at 4ghz so if anyone can help it would be much appreciated!
Machine spec:
i7 920 D0 stepping
Asus P6T Deluxe V2 with 0504 bios
OCZ Reaper 6GB (3x2GB) DDR3 PC3-12800C7 (1600MHz)
Corsair TX650 PSU
Its also water cooled in a Antec 902 case so plenty of airflow and temps are nice and low IE CPU gets to around 68ish on full load @ 4ghz its just trying to keep it at 4ghz thats a pain!
Heres how far I got creeping up through the voltages etc in the Bios, its got a bit better but still locks up while stressing under LinX!
CPU Ratio = 20
BCLK Freq = 200
PCIE Freq = 100
DRAM Freq = 1603
VCLK Freq = Auto
QPI Link Data Rate = Auto
Mem timings manually set to 8-8-8-24 even though they are rated at 7-7-7-24
CPU Voltage = 1.35000
CPU PLL Voltage = 1.88
QPI/DRAM = 1.37500
IOH Voltage = 1.2
IOH PCIE Voltage = Auto
ICH Voltage = 1.2
ICH PCIE Voltage = Auto
DRAM Bus Voltage = 1.64
Load Line Calibration = Enabled
Speedstep = Disabled
C-State = Disabled
Everything else is set to Auto
I have played with everything else on lower settings in different combos but no matter what I try after anywhere between 5 and 30 mins the PC will lock up/freeze (no rebooting and no BSODs) Its being stressed under Vista x64 & LinX 0.6.2
Fed up now so hoping someone will have an idea what to try next, I am a bit loathed to go over 1.35000 on the CPU V core though....
So yeah, err help! lol
Machine spec:
i7 920 D0 stepping
Corsair TX650 PSU
CPU Ratio = 20
BCLK Freq = 200
PCIE Freq = 100
DRAM Freq = 1603
VCLK Freq = Auto
QPI/DRAM = 1.37500
IOH Voltage = 1.2
ICH Voltage = 1.2
C-State = Disabled
