4GB limitation in win2k using FAT32?
tomcat
1,374
I know in win9x there is a 4GB limitation on file size. Does the limitation still apply if you're running win2k with FAT32 instead of NTFS?
Soccer55
1,660
4
No limitation in Win2k. I'm running it right now with my 30 GB drive partitioned into 15-7-7 (the other GB is included as parts of the other 3 because they didn't divide evenly or something)
-Tom
Noriaki
13,640
He said file size, not partition size.
And yes I'm fairly sure the 4GB file size limit is still there. It's a function of the file system, not the OS. If Win2k ignored it and made a 5Gig file, what would that do to Win9x? Win9x can read/write the same partitons as Win2k if they are Fat32.
BFG10K
22,709
3,003
The same file system will have the same limits everywhere, no matter what OS is using it.
