This really surprised me.
In fact, I find it almost unbelievable. Not only did they test some notable memory hogging games like GTA V and Batman Arkham Knight, but they also tested these aforementioned games with 65 chrome tabs running in the background.
And there was hardly any frame rate difference. Now granted RAM doesn't really impact average frame rate, that part at least is not surprising. And the reviewer never tested for things like frame latency or minimum frame rate, which RAM can definitely affect.
But I would think he would have mentioned discrepancies if there were any.
In PCgameshardware's preview of Star Wars Battlefront open beta, they tested for a difference between 8GB and 16GB RAM configuration, and they found a significant difference to be sure.
Personally, I think 8GB is the minimum amount of RAM for gaming these days. 16GB is what I recommend for high end gaming if the user prefers to disable the pagefile, which allows for a smoother and more consistent gaming experience.
32GB is overkill, but RAM is so cheap that if you see a good sale, I say go for it.. The only game I can see in the near future that could potentially benefit from 32GB of RAM is Star Citizen, given it's size, scope, seamless nature and persistent world.
