- Sep 1, 2008
- 21
- 0
- 0
Hi guy,
recently i started to have that annoying clicking sound from my graphics card which after a few weeks turned into a a very loud rattling. Upon inspection i found out that the VGA fan had gone loose and was making contact with the housing.
I have searched the internet and know how to take the card apart but i want to know if i do that will i be able to tighten the fan back to its normal position and if yes then how ?
Any suggestion in this issue will be appreciated.
p.s my card is out of warranty so cant do a RMA
Thanks
Thanks
