Depends on the game. I can run CODWAW maxed out on 1280x1024 with a 4870 and get great FPS, on UT3 setting things on high will lag everything. If I had the money, I'd go for the 4870x2
Overkill.
Any single GPU solution from 4850 performance upwards will be perfect.
Higher VRAM will also help with games with large textures, so look for 1GB versions.
