- Oct 9, 1999
- 15,652
- 3,517
- 136
I recently bought a 2.8E D0 stepping Prescott P4 in the hopes of getting it to 3.5GHz on a 250MHz FSB. The CPU previously in my system was a 2.4C @ 3.0GHz, so I knew the rest of the system could handle it. Along with the CPU I bought a Thermaltake 735 heatsink/fan and a 480W Thermaltake power supply.
I got everything setup and powered on. Everything was fine at default clock speeds, so I decided to start the overclock. Set the bus to 250MHz FSB and left the voltages at default. It got into windows just fine, but didn't pass Prime95. So I decided to raise the vcore to 1.45V. Everything seemed to be stable in Prime95 after that, or so I thought. After about 30 minutes the system just completely shut down. I had to unplug the AC from the power supply and reconnect it before I could power on again. I originally thought it was the temperature getting too high, but just before it happened the second time I was watching the temps. It never got above 60C, which is pretty good for a Prescott. I decided to just overclock at default voltage. The highest I got was 3.36GHz. Pretty good, but not what I wanted.
After about two weeks at that speed I decided to try a better power supply since I got the impression that having to recycle the AC on the power supply was a sign something was tripping. I got the Antec 550W power supply and went for 3.5GHz at 1.45V and everything has been fine since, temperatures and all.
Bottom line... If you're going to overclock a Prescott P4 with voltages higher than default, get the best power supply you can! Either that or stay away from Thermaltake power supplies.
