- Apr 25, 2003
- 380
- 0
- 0
Im not sure if i'ts the power supply problem because I used an Antec 350W before, but then I just bought a KingWin 450W power supply, and my comp seems to gets hotter whenever I play game such as PlanetSide. The CPU temp got up to 53C degrees, I have like 5 fans in my comp, pluse 4 fans inside the power supply, I checked my cpu cooler and it works fine. And the power supply is hotter thant the previous. So my question is does higher power supply generate more heat and so is hotter????
