430W going to cut it?
mlewis
I'm a beginner to computer building, and i'm a bit worried about an antec 430W truepower supply powering some of these hogs:
ASUS "P4C800-E DELUXE" i875P Chipset Motherboard for Intel Socket 478 CPU -RETAIL
ATI RADEON 9800PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -RETAIL
Intel Pentium 4/ 3.0C GHz 800MHz FSB, 512KB L2 Cache, Hyper Threading Technology - Retail
I'm looking (www.newegg.com) at the ANTEC Performance Plus Case with 430W Power Supply, Model "PLUS1080AMG". I assume that it has the truepower supply which i *hear* is good. Is it enough though, to run that mobo/processor/video card combo?
Any insight/info on these issues would be greatly appreciated. I'm open to all suggestions.
Kind Regards,
matt lewis
ya, that will definitely cut it. even a strong 300W psu will be able to support it all your needs if you dont oc.
430w is fine if you don't plan on overclocking. i had antec 480w PSU and had problems with stable rails when overclocking however it ran fine at default speed with 9800 pro, 2 hd, dvd+-/r burner, etc.
