Is there any reason to use one or the other for this type of drive? (LiteOn 52x CD-RW)
I originally had a rolled 80 pin cable on there and had tons of problems installing windows. I was getting all kinds of random errors that Setup could not copy files from the CD. So the only other cable I had was an older 40 pin flat cable, so I used that and had no problems at all. Since then I found some nicer 80 pin rolled cables that are more flexible and stuff (I think the original problem was that the other rolled cable was so stiff and I had to bend it all these wierd angles to fit in the case).. and I was just wondering if it makes sense to use the 80 pin cable or would it not really make a difference?
