ChineseDragon
Rig is 4+~ years old, GPU is almost 3 years old.
Specs up front -
Processor: i7 920 (D0)
Motherboard: Asus Rampage II Extreme (X58)
Ram: Corsair Dominator 12GB (1600mhz)
PSU: Corsair Gold 80Plus, HX750 (750Watt)
GPU: Point of View GTX 570 OC (2560MB)
Case: Silverstone Raven RV02 (old fan version)
HDD1: WD Black 1TB
HDD2: WD Black 1TB
HDD3: WD Black 1TB
HDD4: Maxtor 1TB
Case Cooling: Intake: 3x AT-181 18cm case fan, out: 1x Scythe Kaze Jyuni
CPU Cooling: Megahalems Rev-B, (2x Scythe Kaze)
Monitors: 2 (2560x1440, 1600x1200)
Onto the problem...
I built this rig about 4 years ago with an ATI card and had a great deal of problems with it.
Firstly overclocking it seemed almost impossible, I'm no professional when it comes to overclocking, but I have some reasonable experience. and nothing seemed to make this thing stable at anything like the clock speeds people were getting with apparent "ease".
Secondly this rig runs HOT, or at least what i felt was hot for the amount of cooling I had thrown at it.
Thirdly the graphics card also runs very hot, I'll cover these in turn.
The Temperature, and the sad story of one i7.
When I built the rig I had the idea of running it at 4.0ghz, but after weeks of problems with temperatures I gave up and abandoned the project at the measly stock speeds of 2.67Ghz, and even lowered the stock voltage a bit to try to combat these temperatures, and prolong the life of the CPU.
Stock Speed/slight under-voltage:
Idle: 45-50ºC (average per core)
Load: 80+ºC (average per core)
Ambient: 30ºC - Seems high considering I live in Scotland...
It has run stable at these temperatures for nearly 4 years now, but considering this is stock speeds., it seems excessive. but I ended up defeatist and didn't have money or patience for it any more.
I tried re-seating the heat sink twice over some time, each time with an even finer attention paid to the thermal paste and seating, but no real measurable results yielded.
The story of 1440p is too much for this card.
Originally this rig had an ATI card which got poor fps and was replaced with the current "Point of View GTX 570", i got the 2.5gb version as word on the street is more memory helps alleviate problems with high resolutions.
At this point performance became less of a problem, at 1440p the card gets reasonable to vsync fps in basically everything with max settings.
At the time i was just glad something with the rig was going right, and didn't bother to check the operating temperatures of the card.
... But it's too good to be true for this rig, within a few months the card started black screening and lockups.
I discovered the card was running a stock voltage of 1.088v and could easily break 100ºC under heavy load.
Using NVIDIA inspector i pulled the voltage back to 1.038v, where it has sat for 2 years now with no problems of lockup or black screen, but i tend to stare in paranoia at the temperature dial as it rushes past 80ºC with high-load games, and have taken to running games with no AA (at 1440p the difference honestly isn't huge)
et omega
Now i have a bit of money again and some restored resolve to make this rig work, my first notion was to bury it in the garden and buy everything new, but before i did that i felt it worth coming to you, the community of experts and amateurs for advice on the matter.
I use my build largely as a 3D development workstation (home use), and general gaming.
What is a good path to upgrade from this kind of build? or suggestions where to go for rebuild?
And what insight do you have into what went wrong this time round?
Specs up front -
HDD1: WD Black 1TB
HDD2: WD Black 1TB
HDD3: WD Black 1TB
HDD4: Maxtor 1TB
Onto the problem...
et omega
