Im in a bit of a pickle here. I bought a Nvidia Nforce 680i SLI and a OCZ Gamexstream 600W PSU, which comes with 2 x 4-pin CPU power plugs (CPU1 and CPU2) which is designed for 2 CPU machines, I assume. The Mobo requires 1 8-pin CPU power plug.... it still works with 4-pin, but it says that 8-pin is highly recommended.
What would the 8-pin provide that the 4-pin cannot? I have a e6600 CPU, and I dont plan to overclock it beyond what I could with stock cooling... so probably 2.8-3ghz not more. I also notice that both power plugs fit perfectly into the 8-pin slot, but Im too afraid to turn on the PC with both of them in there, but the PSU manual does say its a "universal" plug, since the main mobo 24-pin plug came as 2, 20pin and 4pin, which could be inserted into the same (24-pin) slot.
Any ideas?
Any ideas?
