I've seen resistor fan cable to run your fan @ 5V for lower noise. But, it's 3 pin to 3 pin. Both my case fans are 4 pin. Is there a 4 pin resitor cable?
Not that I know of, but there are four pin to three pin converters. It'd be a messy way of doing it though. You could just swap the 5v and 12v wires over....
