4 pin floppy wires to 4 pin power supply wires
max105
Does anyone know where to find one of these? Or if not, where I can buy the 4 pin floppy heads so i can make my own?
try jameco.com
for the floppy:
  • number 114930 is the housing (the white part)
  • number 114921 are the pins (you need 4 of these for each housing)
  • number 114999 is what you would find on the floppy drives (pcb mount only)
for the regular drives:
  • part number 42075 is the male housing, the end you would find on extension cables
  • part number 42729 is the male pin for the male housing, you need 4 per housing
  • part number 72067 is the female housing, the end you would find from your PS
  • part number 42649 is the pin for the female housing, you need 4 per housing
