Hi,
I have assembled the following computer:
P5W DH Deluxe mobo
Intel E6600 CPU
Corsair 2GB PC2-6400C4
Thermaltake Toughpower 550W
GeForce 6200 LE
250GB Seagate Baracuda
Floppy, optical drives etc.
Here's the problem:
The computer wont post. BIOS is rev is 1301. I double checked all jumpers. If I plug in the 24 pin and 4 pin connectors and turn on the comp, it turns off right away. If I just plug in the 24 pin connector alone and turn it on, then all the fans start running (including the GPU fan) and all PSU values are within spec even the 4pin connector (measured using DMM). I made sure all cards were set properly in their sockets.
I also tried running with one stick of RAM at a time and that didn't solve the problem. There are no beep codes, no nothing....just the fans (as long as the 4 pin molex connector is not in). The CDROM spins, the tray opens but there's no HDD activity (cuz of failed POST I presume).
My vid card doesn't require additional power btw.
Perhaps someone with experience can let me know if the problem is with the Mobo, or the CPU, or if I overlooked something or perhaps there's some compatibility issue.
I have also tried running the mobo with just CPU and memory. That didn't work either....the psu still turns off when the 4pin connector is plugged in.
Any help would be appreciated.
Merry Christmas!
P5W DH Deluxe mobo
Intel E6600 CPU
GeForce 6200 LE
Here's the problem:
Merry Christmas!
