So is this what I'd need to slow down my loud 120mm fan (a 4-pin to 3-pin adapter, the ZM-MC1, and then give it 5V instead of 12V)? I have a Lian-Li PC-V1000, and the included 120mm fans are permanently attached. The rear is a 3-pin fan whereas the front is a 4-pin.
Zalman ZM-MC1
Zalman ZM-MC1
