4 or 5-channel amp. w/ auxiliary audio input?
Status
Not open for further replies.
Synomenon
10,547
Anyone know of a decent 4 or 5-channel amplifier that also has a built in auxiliary audio input?
I will be getting a Pioneer AppRadio 2 and the only input it has is the USB connection for the iPod/iPhone/Android device. My car has a stock/OEM 3.5mm audio jack built into the console and I'd like to be able to use that still when I get the AppRadio 2.
Synomenon
10,547
The OEM 3.5mm jack is on the dash. You connect an iPod, media player, etc. (anything with a headphone jack) to the 3.5mm jack on the dash. I cut off the end of the jack that plugged into the original stereo and soldered a male 3.5mm plug on that end. I've been using it with all of the previous HUs I've had w/ o any problems.
So now that I'll be getting the AppRadio 2 (which as no inputs whatsoever except for the USB input), I won't have anywhere to plug that OEM 3.5mm input. So I'd like any recommendations on a 4 or 5-channel amp. that has a 3.5mm auxiliary input.
96Firebird
5,738
334
Why not just get a USB to 3.5mm? And then get a USB splitter... Not sure if it would work, but I don't see why not.
NutBucket
27,127
616
Every amp has an "aux" input. Its suppose to be line-level anyway. But will it work the way you imagine? Sort of. You'd have to use your media player/phone/etc to control the volume of the music. Is it idea? No. Will it work as a hack job? Yes.
Synomenon
10,547
I know I've seen amplifiers before that highlighted their 3.5mm input feature as a selling point. I don't remember the brand or model number though.
NutBucket
27,127
616
Not to say you're wrong, but I've never seen such a feature on any mainstream amp. That said, what is about that you like so much about the App Radio? Given the price there are a number of DVD receivers that may suit your needs too.
jlee
48,518
223
if you get something with bluetooth audio streaming, you will not even need a cable. ;)
Synomenon
10,547
I know that. The AppRadio 2 is what I'm set on and it does not support A2DP profile (bluetooth audio streaming).
I'll just look for a place that might still have that Blaupunkt amplifier.
NutBucket
27,127
616
Had a DVD receiver and never used the DVD / CD feature. I don't even have CDs anymore.
All I want is a mech-less receiver to connect my iPod, iPhone, iPad and any other 3.5mm equipped device to.
Here we go (not that Blaupunkt is a great brand), but I found one of the ones I saw:
http://www.crutchfield.com/S-myGCTH...-THA475PnP.html?tab=detailed_info#details-tab
So all they did is put a pair of 3.5mm jacks next to the normal RCA jacks and called it an extra feature? The signal is the same going into either!
Buy a few of these: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=249-138
And end up with the same thing.
jtvang125
5,399
51
Just get a cable like this:
http://www.monoprice.com/products/p...=10218&cs_id=1021815&p_id=5596&seq=1&format=2
and you can use any amp you want. If you need F, R, and sub channels just get a bunch of splitters. For a more professional install get an equalizer that takes a stereo input and splits it into 3 high voltage outputs. Plus you can shape the sound to your liking with the EQ. That was what I did when I was using a tablet in my car.
Synomenon
10,547
Do most amps. let you use both the high level inputs (speaker wire input) and low level inputs (RCA inputs) at the same time?
Status
