0x50 is not common at least to me. I have run into it playing around at 5.5ghz a couple of times when I was playing around with voltages. My current bios seems flakey at higher speeds now. Should have not updated it but those speeds aren't for 24/7 anyways.
Try bumping the mem voltage up a tic or two and see what happens. Check your ram timings to see if they are correct. I'm not sure what other settings your using for voltages tho. 0x101 or 0x124 would be more vcore or pll so possibly VTT might need some adjustment a little bit. Trial and error it and see. You should stress test for stability tho.
