- Nov 26, 2005
- 15,194
- 403
- 126
So I've been looking around on the net on ways to modify my case to mount a 3x120mm rad on top and came across something i thought would be very valuable to the average modifier to make things easier. This is news to me. Apparently a 4-1/2 hole saw will cut just about the right size hole to modify your case for a 120mm fan. The other tools are manila masking tape to mark your measurements and cut spots-n-holes, a 4-1/2 hole saw (120mm fans) and a measuring device such as a combination t-square and of course a drill. For different cuts people are using dremel saws for straight cuts in tight spots or whatever.
I'm sure aigomorla will be like, I could of told you that, but... you never did, lol
Hope this helps,
BTRY B 529th FA BN
Hope this helps,
BTRY B 529th FA BN
