3Ware9650SE RAID controller works in Abit IP35-Pro
MichaelD
31,528
This is a cut/paste of my post in another forum. Some folks here might be interested in this; there are a few of you trying to get a PCI-E RAID card to work in your motherboard. Hope this helps. :)
Tried to be descriptive in the title so a search could find this post.
After months of delays, I finally rebuilt my workstation.
There's been much talk over what PCI-E RAID cards work in what motherboards (or not as the case often is). I know the focus right now is on the X38 boards; I'm a little behind the times.
I'm happy to report that the 3Ware9650SE-8 works in the 4x electrical (2nd 16x physical) slot of an Abit IP35-Pro, rev1.1, BIOS14 (latest bios as of this date). The board came with this BIOS installed, so I can't say for sure if the card would work in the same board w/an earlier BIOS; though I'd venture a guess and say it would. I did not have to hook up the additional 12v Molex connector to the motherboard; it works fine w/o it. I doubt hooking it up would give me any better performance. LOL!
The card was detected right off the bat and has given no problems so far at all. I installed WinXP-32 from a slipstreamed CD with the latest 3Ware drivers on it. Windows setup saw the card, no problem.
The HD activity light on the case did not work automatically; I had to hook up the LED to the card's header, but this was expected.
I've only ran a preliminary set of benchmarks with HD Tach (latest version) and so far I'm a little disappointed. I will post screenshots later (at work now) but going from memory:
(all HDs are 500GB Samsung HD501LJ, 9650SE-8, BBU present)
2-drive RAID0 avg. transfer rate 112MB/s, burst 204MB/s
4-drive RAID0 avg. transfer rate 149MB/s, burst 260MB/s
2-drive RAID1 avg. transfer rate 61MB/s, burst 80-something
3-drive RAID5 avg. transfer rate 72MB/s, burst 90-something
4-drive RAID5 avg. transfer rate 77/MBs, burst 90-something
I was expecting more, especially from the RAID0 setups. I only have 6 drives (case only holds 6) so my testing is sort of limited...can't try with all 8 drives.
I'll post screenshots later to get the exact numbers up, but my memory of them is pretty accurate.
Anyway, just wanted to report that it works.
