- Apr 14, 2006
- 7
- 0
- 0
I would like to run smart fan controls for my CPU fan. The motherboard has a four pin male CPU_PWR connector but every fan I can possibly find that will fit my board (socket 754) are all 3-pin power connectors.
When connecting my 3-pin to this 4-pin I can read the RPM's just fine but the Smart Fan doesn't work. I called up the manufacturer of my motherboard and they say I need to have a 4-pin fan for Smart Fan controls.
I did some searching but I don't see any 3-pin to 4-pin adapters unless they are the kind that converts to the PSU instead of the motherboard. Does such a thing exist? If not, any other ideas?
