3dmark05 and aquamark3 scores are they low?
3dmark05 looks about on, but I wouldn't take and benchmark to be worth more than what comes out of your buttocks....you really wanna test it, use the timedemos in Doom or FarCry or something that is real world situation based.
Originally posted by: compgeek89
Originally posted by: otispunkmeyer
Aqua mark is getting long in the tooth now......its probably cpu limited
PROBABLY?
FOR SURE would hit the spot 😛
Aquamark should upgrade to 1280x1024, 8xAA, 16xAF default to show the real deal 😉
Originally posted by: JRW
Originally posted by: toattett
He is just trying to show off, nothing much.
Nailed it.
Why am i trying to show off cause i put my scores like about another 300 people here?
what a f!@#$% joke.
For those of you that are taking it this way, I ask you why?
Specially coming from someone that has to list on their sig their previous high dollar
items (x2 4400+ (2.4GHz @ 1.30v) from FX-55
DFI SLI-DR from ABIT AV8 3rd-eye
OCZ 2 x 1GB @ 2-3-2-5 from OCZ PC-4000 VX from Corsair XL Pro
CM Stacker + Neopower 480 from WaveMaster
eVGA 7800GT SLI from eVGA 7800GTX KO from 6800GT SLI from x800xt PE
X-Fi XtremeMusic from Audigy 2 ZS )
IF THIS IS NOT SHOWING OFF WHAT THE F$%^ IS? GET THE POINT toattett
Nailed it.
what a f!@#$% joke.
Hmmm, let's see... you created a thread to draw attention to yourself and asked everyone the ridiculously stupid question, if your scores were "low" knowing very well that those scores are practically double what the majority of the members on these forums can get, Just a thought...
Maybe if the OP change the title to "Are these 3DMark05 scores low for 7800GT SLI" . . . 😉
Still though what he's trying to do is obvious . . .
I gues I should have change the title as on for sli setup, not trying to compare to single cards here. I go to many different forums and this is the only one that some people act like f#$% kids. how about an instructive answer. for an sli setup is not or it is a bit low. then i can go back to the drawing board and keep tweeking.
grow up
So why exactly are you taking so much offense to a little statement? Perhaps it's true?? Hmm, not sure, but if you have seen "300" of different peoples scores, then you know what 3d mark is acceptable. The only reason I can see is to show off. Nothing more.
Maybe everybody is overreacting...
In any case, im not impressed with that aquamark score at all
Especiallly your cpu score is pathetic for a FX 55...
All air, 1 X800XT and a 3500+ >
http://img460.imageshack.us/my.php?image=aquamark3highest5dw.jpg]
[/URL]
(in case you are wondering, yes im showing off)
Anyways thread starter, your cpu score needs some work
And what about this "aquamark is cpu limitied" .. What good is a bench that only tests your card and shells out the same scores for say a sempron with a 7800 and a fx-55 with a 7800
I know how fast my card is, equally fast as every other card with the same clocks on the planet, i want to know how fast my system is instead ...
Aquamark being cpu depending is the whole point ....
[/URL]
again you were not even close,(only your cpu scored higher, since you are clocked higher duh). As far as total system performance not even close even with your cpu at higher speeds than mine.
I will clock mine to 2.9 then Ill show off for real, man i thought you had 100+ score the way you were writting as a system score, guess not all you have is an oveclocked cpu. nothing else in your system is worth looking at. you are not very smart if you see my cpu speed atm you are faster than me. aquamark is very cpu dependant.
My score is not so pathetic since my cpu is clocked lower than yours and my system still eat your for snack. try and score at least 2k more points next time.
Show me a prime95 shot 10hrs stable like my system is now. I bet you can't. NOW I'M SHOWING OFF) I'm just getting started with this little project of mine.
Sleep tight,
p.s do not forget about those pics of your prime95 stable system @2.92mhz with cpuz on same pic
peace
[/URL]
Sleep tight,
peace
Very well said
