3Com Home Ethernet Router - Disabling Firewall - I NEED HELP!!!
TheLizardMan
881
Okay, what do I do to disable the firewall? Also.. is the new SMC firmware what I should use or what? As you might know I got this at Tiger for pretty cheap after 3com stopped supporting it.
Garion
2,331
7
In most of these broadband routers the "firewall" is simply Network Address Translation (NAT). It's integral to the device itself and is the feature that allows multiple PC's to share a single Internet connection using one IP address. You really can't turn it off, unfortunately.
- G
