$89.72 at TigerDirect (Open Box but comes with 3-Yr Manuf. Warranty according to Tigerdirect)
This is a Corporate-grade professional WLAN AP, which is a rebaged Symbol Technologies AP4121 Access Point with 100mW Transmission power, Reverse Polarity BNC connector for an external antenna, and a Power Over Ethernet (PoE) power supply which allows DC power to be fed through Cat-5 Wiring. Supports 128-Bit WEP too. This thing retails for $600.
However after a little bit of research, this product is discontinued by 3Com, and the latest firmware is dated 5/02. The reviews say the performance is great but setup may be difficult. But no other AP at this price range has the PoE and 100mW transmission feature.
Practically Networked Review
3Com Support Page
Comparison of the 3Com/Symbol unit with other APs
P.S. use a credit card w/ good return protection policy since TigerDirect's reputation is quite mixed
Thanks to ADA890 for pointing, Tiger is selling the 3CRWE747A, which is the rebaged Symbol AP4121.
3Com Support Page
