- Aug 20, 2010
- 1,931
- 95
- 91
I've looked all over the net for help on overclocking this chip, and most of the good guides are way too in-depth, confusing me to no end!
My objective: 4.0 - 4.5Ghz (Constant 24/7 OC), while keeping my RAM at it's X.M.P speed of 2133Mhz and appropriate timings
My Components: Gigabyte X79 Assasin2 (F10 bios)
G. Skill RipJaw 16GB @ 2133Mhz XMP
i7 3930K w/ H100 Push/Pull
SSD/ 1k Power Supply/ GTX 6704GB SLI
The first thing I am confused about is bclk overclocking vs. using multipliers and/or straps.
Also, do I need to use Turbo Boost to OC this chip ? Should I be using it anyways ?
Will upping the multiplier change my RAM timings/speed around ? Will I have to keep playing with it to keep it at 2133mhz ?
I have seen that anything under 1.5V is 'safe' for this chip. How much will Vdroop affect this chip ? Will the voltage change while I am gaming etc. ?
My brief knowledge of overclocking this chip is to up the Vcore, disable C1e and speedstep etc. and bump the multiplier up until it is unstable. Does that sound about right ?
Somebody please give me a basic step by step guide on how to OC this chip. Maybe four or five steps, I'm not trying to set overclocking records and I don't care HOW it works just if I can get it to work!
If anyone knows a decent guide somewhere please post up a link.
Lastly, if anybody has overclocked on this mobo specifically your input would be very great!
