I got done playing 2 hours of Battlefield 2. And lots of .NET programming. It is definitely stable. No need to run prime.
Horrible reasoning..
Run Dual Prime and see where you max out at.. You probably have a stable 2.7ghz in there..
Originally posted by: chinkgai
Originally posted by: Gronich
Originally posted by: formulav8
Also, I did mess around with 2.7ghz for a few minutes but after awhile its a NO GO. It really starts to warm up at that speed too.
2.6ghz is plenty fine for me anyways. I probably won't even keep it that high. 2.4ghz will do me just fine. It is equal or really even a bit better than the 3400+ (2.4ghz) s754 Newcastle I have in Single threads and really put it to shame in multiple threads. Yeps, should suit me just fine 🙂
Jason
Just for your interest, I'm running the same core revision as you JH-E6 (Manchester/Toledo?).
X2 3800+ 2.8Ghz@1.4v Prime stable 13hours+
So, all things being equal, I think there should be a little more in your chip @ 1.4volts.
dude, i think you've posted up this picture several times but you still have NOT posted up a dual prime stable pic???
Originally posted by: IceMole
Seems this stepping is the current one being shipped out from ZZF. I got mine yesteday, same stepping. I've noticed this thing HATES overclocking from windows. Over at [ H] a guy has the same stepping doing 2.9 @ 1.57v dual prime stable. I'm at 2.6 @ 1.41v for 8 hrs so far. These suckers can heat up though, dual prime with my XP90 gives me 52C, using the new S&M dual full load gives me 59C!
Try using this and see what your max temp is:
http://www.thecoolest.zerobrains.com/forums/viewtopic.php?t=83
mine is 67C
mine is 67C
I copyied the info to the clipboard and this is what it gave me:
CPU Information (CPU #1):
Standard CPUID: Family: F, Model: 3, Stepping: 2
Extended CPUID: Family: F, Model: 23, Stepping: 2
CPUID String: 20F32
Processor APIC: 0
Processor: AMD Athlon 64 X2 3800+ (Toledo)
CPU Speed: 2600.11 (260.01 x 10.0)
Revision: JH9-E6
Platform: Socket 939
Startup VCore: 1.350v
Maximum Case Temperature = 69C
Written by: Arthur Liberman.
Idea by: Petr Koc.
More info at: http://www.thecoolest.zerobrains.com/forums/viewtopic.php?t=83
I don't see where it says what the actual cpu temp is??
Edit: I see what you are talking about now. As you can see, mine says 69C. So, in theory, it could be a better ocer than yours then 🙂
Originally posted by: Shimmishim
the best way to deal with heat is to remove the IHS.
i hear people gain overclock due to the decrease in heat.
i recently removed the IHS from my SD and i dropped 7-8C's load which is pretty significant.
Any guide/tips to removing it safely?
Jason
The dual prime stable piccies I have seen didn't seem to contain any times in them so I didn't feel it was relevant. But I just noticed bjc112 pic with the Task manager times...If you feel it is of interest to everyone I will run prime95 tomorrow and post the piccies.
oh btw, it would be nice if you stopped it so we know how long it ran for...like this:
http://pics.bbzzdd.com/users/chinkgai/primeshot2894.JPG
