OK First of all I have a mini ITX ASUS deluxe board in a Btfnx Prodigy, Crucial 2400 @ 2133 8 GB ...ssd 128 Crucial , 3770 k with an H-100
1- i delidded the CPU, at first I applied artic Silver 5 on die and IHS at 4.7 temps where going upward 80 c to 94 celcius not satisfied then .
2- I ordered liquid metal pro I applied on die. and I also bought PK_1 for IHS to H-100
3- I lapped CPU only up to 2500 grit . I left the h-100 alone It looks like a pain in the butt
4-ran some preliminary tests with the case meaning my Bitfenix closed as I am going to use it no open air to have more realistic expectations
5-@4.7 GHZ temps dropped at least 15 celsius to 20 celsius now it does not go past 70 Celsius on prime small ffts or Intel burn maximum settings
My concern is the volts , I have it set on offset and it goes up to 1.35 to 14 I have been using the software that comes with ai suite but as I lower the volts once I read 1.88 on CPUIZ it gives me a BSOD I tried setting the volts manually on the BIOS but then PC wont even boot . I seee some people with some nice lower volts and I would like to see this with mine. I do know every waffer is different but I think I m running volts unnecessarily high for 4.7 I value your opinions highly. Please I don't want to start a debate on the voltage I just simply would like to get an education on extreme overcloking with low volts if possible. Keep in mind I am using this rig for FSX as this game is so cpu hungry . Oh by the way after delidding I got 9.99 cinebench score which I never saw before on this chip. That was at 4.9 ghz volts were like 1.45 but with the offset I saw them at 1.56 any help from your success would be greatly apperciated
