3200+ winchester with a8v.. no post.. please help
Appledrop
hello
i received today all the pieces for my new gaming pc, from dabs.
i ordered :-
a64 3200+ (winchester)
asus a8v deluxe - i would tell you the revision, and bios number, but i cant get that info unless i post 😱
1x512mb corsair cl 2.5 pc3200 value select
asus x800pro vivo
antec case with 400watt smartpower psu
rest of gear irrelevent i think 😉
ok, well.. after setting it all up, feeling pretty confident, i power up, and no video display, just all fans working, and Cdrom and floppy lights going. This kind of thing usually happens first time round i think to myself, so i go through the normal procedure:-
reseat ram, (in B1 slot, as per the manual)
reseat graphics card
reseat CPU
No luck
try different ram stick
try different graphics card
No luck!
i googled a8v 90nm for problems, and hear that it will not boot with 90nm cpus unless just 1 stick of ram is in dimm slot B1. Strange, thinks i - thats the slot mine is in... and i saw that unless your stick is in B1, you will hear "computer not boot becase of CPU overclocking" with asus's voice reporter.
So, i tried moving the ram to slot A1, and hey! i hear "computer not boot because of CPU overclocking".
but it does not do this when the ram is in B1.
So, basically, i still cannot boot, and am totally baffled.
does anyone have any ideas please?
thanks in advance
Does the bios support the 90nm cpus without a flash update? What does the Asus site say about that? What is your PSU? Do you have a friend with the 130nm 3500+ or higher to try in the motherboard to see if it works?
Topic Title: Dual Channel Memory Problems with Asus A8V (go to this topic in the motherboard forum. It sounds like your exact problem)
yes, i think so. but according to others with my board, it should be able to post if you have just 1 stick of ram in B1.
my psu is antec 400watt
no, i dont have any friends 😛
