After using my computer with my new Corsair 300r case, I found out that my audio ports were somehow reversed when I plugged in to get sound from my headphones. I found out that the USB ports are having some grounding problems as well. The computer would completely freeze every time I would even touch a USB device to the front port.
Checking for a ground, I popped off the top cover of the front panel. You can clearly see that the Audio ports are reversed. I bet there is something wrong with the ground as well.
My luck is not on my side today I guess.
