I got a Netgear 834M wireless-N router and WN311T wireless-N PCI card for about $100 for both when CompUSA was closing up. As I am installing them tonight or maybe tomorrow as it is getting late now, I got thinking....
Together they are supposed to do up to to 300Mbps. But the router ports are 10/100. So how could you ever transmit data at 300Mbps? I will find out when I get it all going how fast they are, and I will by satisfied with 100.
Am I not understanding something here? The wireless may have the capability to transmit at 300, but the wired ports that feed the wireless are only 100. So what is the benefit of wireless-N without a gigaswitch in the router? Any enlightenment will be much appreciated.
******6-3-07 Set up the router and adaptor and according to the monitor program that comes with the adapter, I do transfer files at 300Mbps!!!!! And that is in another room across a hallway.
A 67 meg I moved with my old Airlink MIMO router/adapter took 25 seconds, with the netgear N 14 seconds, a 101 meg file in 21 seconds. It takes a few seconds to get up to speed, but it is clearly much faster. Should help the lag we used to get on lan games, which is why I upgraded.
Could it be that the router/adapter are connected at 300 and are actually transferring at 100? If that is the case, why build a N router without a gigaswitch. I would think that the monitor would show the actual transfer speed and not the connection speed to be useful.
Maybe the 10/100 numbers not be the same measurement as the wireless transfer numbers? I do not know how it works, but it does!
Posted this in the networking forum and did not get much response, I would sure like to know the explanation for the above if anyone knows.
Thanks
Thanks
