$300 to spend on monitor. Need Advice
Xenon14
I have about $300 (shipping included) to spend on a monitor. It has to be at worst .26 dpi, at least 1600x1200max res, at least 75ghz refresh rate.
Right now I'm looking at Samsung SYNCMASTER 950P 19INCH, 18.0 viewable, . 26mm dot pitch, 1600 x 1200 85hz ($ 239 + $40.40 shipping)
I don't really know my way around monitors, so any suggestions would help a lot. Thanks.
tornadobox
2,081
Just a note, you might do better to go to your local computer store/best buy/circuit city and pick up a monitor...you'll save a bunch on shipping.
Xenon14
Thanks,I'll check out my local stores. In the mean time, do you have any suggestions about what monitors I should look/ask for?
acidtear
43
just take a look at em, if ya think they look good, get it
i would recommend a 17' trinitron
arod
4,236
For 300 you should be able to get a medium quality 19"
I personally like the KDS line of monitors and they are cheaper than most.
But yeah the best way is to look at them at you local best buy
tornadobox
2,081
With $300 you could either go with a very nice 17" or a decent 19" (depending on the features you want most). If you want a completely flat screen surface (not talking about Flat Panel Displays here, but regular flat-CRT's), then you want either a Trinitron tube or some variation of it (like the Diamondtron tube I have in my monitor). I personally love flat-CRT displays, but some people don't like them. In any case, monitors are just a matter of preference, go to best buy/etc. and just play around with a few. I'm sure you'll find one that you really like :)
Bojax
757
You might want to check this out. Samsung 950P I just did this deal. I have been doing the research on a 19" monitor for at least a month now. I feel very comfortable with my decision.
NelsonMuntz
1,827
Before you go waltzing in to your local store to buy a monitor to save on s/h, check out egghead.com. They have $6.95 flat shipping rate on monitors which would be much less then the tax you would pay at a B/M Best Buy. So the trick is check the prices at egghead and price compare to those at Best Buy and buy from the cheaper place. That's what I do. BTW I like the KDS model line because it is less expensive also. I have a 19" at home myself. As an example, egghead.com has the KDS VS-19SN which I think meets all of your requirements for $224.99 right now and shipped that's only $231.94. Much less than your $300 cap. Just letting you know. They also have your Samsung for $294.94 shipped which isn't a bad price either.
bigbootydaddy
Banned
Sep 14, 2000
5,820
if u like to gamble, monitorsonsale.com has some nice trinitrons 21" around 300, and they give u a good year of warranty...
will be flamed
V
BBD
arod
4,236
My 21" monitor at home was from monitoronsale.com and its now 2 yrs old and looking as good as the day i got it
