300$ for Electrician to setup Network
Bird222
3,641
132
If you're talking certifying the runs, CAT6A is very hard to terminate to spec - 'to spec' being the the key word. The cabling guys I worked with were experts who had literally thousands of terminations under their belts, BICSI certified and all that, and even they had some runs among 100+ at a customer site that failed certification. They were certifying the runs with a $6,000 cable tester and most electricians and even many low voltage experts don't own those types of units - let alone the ability to terminate runs to where it's actually worthwhile to test them. If OP would decide to go with CAT6A an 'electrician' is not gonna cut it in most cases.
Side note: Make sure you get the scope of work in writing and make damn sure there is something in there about NOT terminating to RJ45 connectors. If the installer crimps cables they are not low-voltage experts. Also, if they staple any runs, you should slash their tires. Nah, I'm just kidding (mostly).
How should they terminate the cable?
OSULugan
289
I had an electrician come out to give me a bid to run 12 Ethernet lines (6 distributed locations to 1 central location), a single electrical outlet, and some media cables pulled through from where we were mounting our flat screen TV on the wall while he was at it (since Ethernet lines were going there anyway). The quote was close to $4k.
I ended up doing the runs all myself, have a couple hundred feet of leftover Cat6 cable rated for in-wall installation, a bunch of new tools and a much more familiar understanding of how my new house is setup. It cost me WAY less to do it. If he'd quoted me around $75 a drop, I'd probably have just had him do it for convenience sake. But I would've been pretty unhappy to have RJ-45s crimped onto the end of the solid-core cable rather than a patch panel and keystone jacks.
azazel1024
901
Yup, just really depends on where you are and what electrician you talk to.
$4k is roughly the cost to wire up an entire house (if a small one) with romex, let alone doing six pulls of ethernet and an electrical outlet. I mean, crap, unless a mansion, that is maybe one good solid 12 hour day for most electricians in a medium sized house, maybe with a bit of clean up work the next day or something. Short of them being very, very complicated pulls.
I wish my hourly rate was ~$300+.
It is part of the reason I typically do a lot of my own work. I understand these guys are trying to make a living, but I've had to many times I've gotten quotes on work just thinking it would be easier to pay a bit in labor to have someone else do the work for me and had to restrain from laughing at the person on the quote.
"Oh, yes, I agree, $800 to relocate a sink with the walls already open, perfectly reasonble. Let me not call you back."
And 6hrs later, dust hands off and put away torch, left over pipes and get out the dust pan and brush. "Honey, I just save 780 dollars!"
That said, I do occasionally contract out work, its just rare that I find someone who is charging what I would consider fairly reasonable prices. Example, I hired a guy to redo some brickwork on the front of my house where I closed up a door and moved a window. Probably did a better job than I could have with the brickwork and he charged $300 for 3/4 of a day of work. It probably would have taken me closer to a day and a half...and also probably just wouldn't have looked quite as nice. Worth it.
Quotes I've gotten on electrical, plumbing and a lot of other stuff, rarely worth it.
I'd pay most people to do dry wall work (at least on a large scale) in a heart beat. I hate to do it and they can generally do it in a third the time, looking slightly nicer (I am pretty good at it, but not amazing) and they often charge reasonable prices.
night
510
If you are in a 1 story running new stuff is easy to do yourself.
I'm in a new house with 5e used for the phone. I swapped the face plates, put a 16port in the attic and called it a day.
On the other hand, I had someone come in and put in a power plug in the ceiling for a projector. They pulled a new romex down to the wall plug + the 120outlet for.. (at best memory) ~150. And did it over my lunch break.
OSULugan
289
I should note that I figured the electrician just didn't want to deal with the low voltage stuff, and quoted me high on purpose.
imagoon
5,199
You are likely better off. Residential electricians tend to not "get" Cat 5e. Hence why you often see it tied together like phone lines.
azazel1024
901
Alarm installers are actually a bit better bet if you have any independent ones around you. They often do network and phone wiring installs too.
I have deffinitely seen guys quote high on purpose either
1) Because they didn't really want to do the job
2) The job was small, so see #1
