$30 Audigy Value better than onboard Realtek?
slowpogo
102
I've been looking at 939 mobos lately, and the concensus for most popular boards seems to be that the on-board sound (usually Realtek ALC850) is only "OK" and that an external sound card would be yield lower CPU usage and better sound.
If that's the case, what level of sound card would you need to get to improve on typical on-board sound? Would a $30 Sound Blaster Value card actually be a substantial improvement in CPU usage, if not sound quality?
shortylickens
80,287
17,081
The CPU usage in audio is a hot debate and I wont get involved with that.
I would say that the audio quality is better but then you have to deal with Creative drivers. For a low-end card its just not worth the heartburn.
PhoenixOrion
4,312
if you have a nice set of speakers, any decent add-on card makes a big difference in the amount of noise (reduction of).
deadseasquirrel
1,736
What speakers do you have? A simple 2.1 setup with good 939 audio (like the DFI or Asus) will be very hassle-free, cost nothing extra, and be very comparable to a low-end sound card in both sound quality and cpu usage.
