3-Way & 4-Way on Z87
adnank77
125
I've done some research and here is what I've got:
- Z87 has 16 PCIe Lanes as a total.
- If I use 2 Way SLI or Crossfire, the graphics cards work as 8x/8x
- If I use 3 way crossfire, the graphics cards work as 8x/4x/4x .. SLI doesn't support 4x so 3-Way SLI is not supported natively on Z87
- To achieve 3-Way and 4-Way SLI and CrossFire in Z87, a PLX chip is needed.
Questions are:
- What does the PLX chip do and how does it distribute traffic between lanes? Could someone please refer me to a link where I can read some details ..
- Any drawback of using it? I keep hearing that native is better, but better why?
- If I have dual graphics cards running as 8x/8x .. theoratically I'm consuming all the Lanes .. Can I add a different card (e.g. PCIe SSD or Sound Card) or do I still need PLX for that ?
MiRai
159
I believe there are some technical details here:
http://www.plxtech.com/products/expresslane/pex8747
I don't have an answer for this, but I've heard the same thing.
On an 1150 board w/o a PLX chip, I would assume adding a third card which takes up a slot on the motherboard is going to drop one of the 8x slots you're already using to 4x.
