3 volt on motherboard
goldjunge
Hi
i found a pretty cool device at spencers i would like to use in a pc build it is run by 2 aaa batteries.I did already connect it to a psu with a v meter, and it runs great on the 3.3 volt rail of the main psu cable.I would like to put it in to the case but i dont no any pin on a mother board that gives me 3.3 volt.I would really apreciat any help , i am building this pc for a donation "Arts for Act" so i want to make this build perfect.I speak perfect german and good english.
Thank you very much
Pete
Modelworks
16,240
7
You would need to tap into one of the orange wires (make sure its solid color and not a orange and black stripe) on the ATX connector.
Zepper
18,998
Yeah, the easiest would be just to tap into one of the orange wires and a ground (black) wire if necessary. Most any stores that sell electrical stuff, even auto parts shops, sell wire taps that make it easy to connect other things to a wire. The 3M Scotchlocks are the originals. Here is a link so you know what I'm talking about: 3M Scotchlock Connectors
Just get ones that match your wire gauges - it is marked on the orange wires in small letters (get out your magnifying glass) - it will say something like 18 AWG or 20 AWG (AWG means American wire gauge - as those are the two most common gauges of PSU wires) - ones for diff. gauges are diff colors depending on brand - cheap chinese knockoffs are already out there. Radio Schlock has some at their usual mall prices; auto parts stores, and the big box stores like Home Depot, Lowes, etc.; hardware stores, etc.
.bh.
goldjunge
Its a little disc ,about 2 inches in diameter,when its turned on it creats like lighting but in colours.It is all glas with one wire coming out of the back ,so i tink it is under a vacuum or presure because it is fully incloused.I bought it bacause it is very visible and had a clip.I use it when i walk my dogs at night so cars can see me .But i really would like to put it in that case because it is so unic.It was about $20 at spencers.
Check it out alaricljs.
pete
goldjunge
Thanks
Modelworks and Zepper,
I read a little bit more since last night on the net and all i could found out that the 3 volt cable on the main psu cable is for the memory and the cpu.I thougt there might be a fan , drive ,or any plug on a motherboard that would provide me with the 3 volts.But if there is no problem to tap into a cable from the main psu cable ,that works for me .I do not no squad about electricytie,besides you touch a cabel that carries 220 v you see black for a while.everythink i know about building pcs i learnd by reading on the net and with help of people like you that share the same pasion as i do.
thank you very much
peter
goldjunge
thanks Zepper
Thank you for the link to this 3m website ,you just opend a nother door for me ,this site gonna be my bedstory for tonight.
thank you
Pete
