I was looking at some 3 pin Y splitter cables and it seems that one of the ends is a normal 3 pin connector, but the other only has 2 pins... I've seen this on every 3 pin Y splitter I've seen... Why? I can still power two regular 3 pin fans with it, right?
Also, one other question, I've heard it is not good to run higher power fans off of the 3 pin connector on the mobo, but to get a 3-4 pin converter and run it from the power supply. I've heard the high power fan can ruin the mobo, is this true? I have an Asus A7V-133 mobo and I am running a 80mm 5700 rpm (I think it only runs at 5200 rpm though) delta fan off of one of the 3 pin connectors on the mobo... will I be ok? Its been running for like 8 months now.... Btw, I have a 300 Watt power supply....if that helps any...
