hi i'm going to buy the asus p8z77-v pro and install more fans than the number which this motherboard supports, and propably i'm going to use 2 pin splitters for the extra fans, do you know if these fans can be controlled through the fan xpert2 utility of asus? or do you recommend me to use a molex to 3 pin from psu and a fan controller in order to control activate/deactivate that extra fans, if yes which fan controller do you recommend?
thanks
thanks
