Originally posted by: napes22
Thanks for the direction. I had no idea you could shift the wires over without damaging the plug.
Originally posted by: Saku
I am having this problem right now, hopefully the needle thing works.
Can I use the same pulg and just switch out the wire?
If I do this the plug slightly bends the pin on the mobo that sits next to the power led pin because its meant for a 2 pin not 3 pin. Should I be concerned about this?
Thanks ppl.
EDIT: nvm won't work with the same plug because the pwr switch connector wont fit if I do that. I will either have to buy/pirate a 2 pin plug or an adapter. ><
