3 Pin or 4 Pin Case Fans
prsobel
22
What is the difference between 3 and 4 pin case fans? Which is preferred, and why?
conlan
3,395
3 pin fans connect to your motherboard , 4 pin fans connect to your power supply . i prefer 4 pin fans connected to the power supply as 3 pin fans have the possiblity of burning out the motherboard header.EDIT- however with 3-pin fans you can monitor fan RPM if you want.
jamesbond007
5,280
Another vote for 4-Pin fans. RPM monitoring is nice, but it isn't needed. With 4-Pins, you can daisy-chain a setup a lot easier as well.
lhampel
403
Depends on the 4 pin model...There are 4 pin model fans that actually monitor the RPM & TEMP readings.
(temp goes up, RPM's rise..Temps go down, RPM's fall)
But, you'll need a server board to use these cool fans though. :]
