3 Issues - One problem?
Status
Not open for further replies.
bTaryag
Hi all. I'm trying to figure out what this can be. Three symptoms started more or less the same time:
1. Car vibrates. Not the steering wheel, but the whole lower front end of the car has right-to-left vibrations, mainly at speeds up to 30 mph, mainly when accelerating, particularly bad when driving uphill.
2. When I go over a bump, sometimes there's a thump-like noise from the front right or front left of the car. This issue only exists when the car is cold, but once it's been driven for a while it doesn't happen.
3. When the car is stationary and I turn the wheel from side to side, I hear a clicking noise from under the car. (I sometimes think I also feel it from under my foot.) This only happens when the car is in drive, not in park or neutral. Like issue #2, this issue only exists when the car is cold.
Any thoughts What could this be? Is this one problem or a few separate ones?
Thanks for any help!
In addition to the sources above, check suspension links. Tie-rods, bushings, strut mounts, etc.
Status
