3 hd monitors system
alberto.priore
Hi,
I need to create a system with this configurations:
I have 3 hd 37" monitors placed in vertical mode 1080x1920
I need to show on the 3 monitors 3 web browser (I don't care which operating system)
I need to connect to internet the system ONLY with a usb o pcmca modem umts/hdspa (becouse I do not have the possibility to connect the system to a lan)
I need to remote access to the system maybe with Hamachi or others.
I need to auto power on the pc and to controll the bios to change the time to power on the pc remotely.
(I find that to auto power on the pc is there a config called Power on by RTC Alarm and so I needto config this maybe with a system like this -> http://www.delltechcenter.com/page/D...on+Utility+3.0 )
What others people suggest to me is to buy 1 pc with 2 video cards that support 1080x1920 resolution
or to buy 3 mini pc and connect one with the modem and share the connection to the other 2
but for the other needs that I have I do not found someone that suggest me something good for all.
Can you provide me a solution for my needs?
Thanks in advance!
