3 displays using onboard vga
jay75
I have read that if you have a mobo with the ATI 9100 IGP, then by adding a dual vga/dvi ATI radeon card one can have a 3 monitor setup. is there anyway to get this to work with an nvidia AGP card(geforce ti 4400) and an onboard S3 Graphics ProSavage8? 128-bit 2D/3D Engine? I know the onboard graphics are disabled when an AGP card is installed, but is there a program that can override this and overcome the different graphics driver conflict?
No. The ProSavage can't pull that trick, and it always vanishes when you plug an AGP card. That's a hardware limitation, mainly in the AGP restriction that you simply can't have more than one AGP device in the system.
The ATi IGP can transmogrify itself into a PCI device when you plug an AGP card - and that's a trick that must be implemented in hardware.
