3 Case fans not working, please help.
ask83r
Case: https://pcpartpicker.com/part/rosewill-case-galaxy01
Motherboard: https://pcpartpicker.com/part/asus-motherboard-z97prousb31ac
I have three fans to hook up and here are the parts they look like
http://puu.sh/kprqD/3ea6a64488.jpg (no. 1 and 2)
http://puu.sh/kprrF/1444d87796.jpg (no. 3)
So I plugged this into channel fan
http://puu.sh/kprI8/c741ccc7cb.jpg
and plugged no 1 and 2 into it like so
http://puu.sh/kprsd/a1a7e3c624.jpg
no 3 still is not plugged in but when I turned it on, non of the fans work except my CPU fan (which I won't even include in the post since it's working)
Any ideas? There's no 3 prong pins on the board to plug no 3 into anyways.
Thanks!
Umm...that board has 4 chassis fan connectors and 2 CPU fan connectors.
Were you thinking you couldn't plug the 3 pin fan plug into the 4 pin mobo connectors?
Well, you can. :biggrin:
Plug each chassis fan into a chassis fan connector. Look closely, you'll see that the 3 pin fan plug will fit the 4 pin mobo connector. The mobo connector was designed for both 3 and 4 pin connectors.
In the BIOS set these 3 pin fans to DC control, and set the CPU fan to PWM control.
http://img.bhs4.com/DB/C/DBCE7D7D74819B7BC287C7A93EED64D831CA56EE_lis.jpg
This right here.
I'd be very surprised if that board did not have connectors in several spots for fans, you can put a 3 pin fan on a 4 pin mobo connector.
